RE: Building a MultiPLex E-BIgLIft
ok today we gonna stick all together. alignment is important.
you can see already the battery tray. there is enough space to put from 3s up to 10s if you need it.
all plywood is 1.5mm. critical positions are enforced with layers of playwood.
most is glued with wood glue. this glue gives still some kind of flexibility other than superglue.
