RCU Forums - View Single Post - Servo mounting isolation
Old 09-30-2010 | 08:23 AM
Charlie P.'s Avatar
Charlie P.
Default RE: Servo mounting isolation
The manufacurer recommends isolation mounts and goes to the trouble to supply them with every servo.  I have never not used the grommets and stand-off bushings, so I can't say the teeth will all fall out of the servo simultaneously and at the worst possible time if you don't.
I take it this is an electric model?  Perhaps direct mount is good enough.  Some just stick the servo in place with two sided tape.  I wouldn't do it on a model with an I/C engine.
