RCU Forums - View Single Post - Servo mounting isolation
Old 09-30-2010 | 11:19 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Servo mounting isolation
IF it's a glow powered plane then you DEFINITELY need to have the rubber isolation mounts for your servos.
As Minn indicated, you need to make sure a servo is only touching where the rubber mounts on the mounting tabs are. I usually use a 1/16" piece of balsa for a spacer similar to what Minnflyer shows above.
Ken
