RCU Forums - View Single Post - Servo mounting isolation
Old 09-30-2010 | 12:44 PM
Clay Walters
Default RE: Servo mounting isolation
Biff,
While they will work either way, by putting the collar end on the wood its less likely to cut into the mount. That said, I've tried it both ways, both ways keep the compression of the rubber in check and the sharp end has not produced any issues resting on the wood. But I always "harden" the holes with CA too.
Regards,
Clay
