RCU Forums - View Single Post - DL-55 Starting problems
Old 10-01-2010 | 07:17 PM
moami
Default RE: DL-55 Starting problems
ORIGINAL: jedijody
Hereis the top secret inner workings of the DL/RcExl plug cap revealed. In the first picture you can see the broken off post of the resistor right below the cap, this is all that was wrong with this dead ignition, the second picture shows a new resistor and how it contacts the small spring that hits the spark plug if it's pushed on all the way. The resistor is there because the CM-6 type spark plug is to small to fit one in the spark plug to suppress RFI.
<![if gte mso 9]><xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w:PunctuationKerning /><w:ValidateAgainstSchemas /><w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid><w:IgnoreMixedContent>false</w:IgnoreMixedContent><w:AlwaysShowPlaceholderText> false</w:AlwaysShowPlaceholderText><w:Compatibility><w:Br eakWrappedTables /><w:SnapToGridInCell /><w:WrapTextWithPunct /><w:UseAsianBreakRules /><wontGrowAutofit /></w:Compatibility><w:BrowserLevel>MicrosoftInternetE xplorer4</w:BrowserLevel></w:WordDocument></xml><![endif]><![if gte mso 9]><xml><w:LatentStyles DefLockedState="false" LatentStyleCount="156"></w:LatentStyles></xml><![endif]><![if gte mso 10]><style> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin:0in;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman";mso-ansi-language:#0400;mso-fareast-language:#0400;mso-bidi-language:#0400;}</style><![endif]><p align="right" style="text-align: left;" dir="RTL" class="MsoNormal"><span style="" dir="LTR">Sorry for my bad english!</span></p><p align="right" style="text-align: left;" dir="RTL" class="MsoNormal"><span style="" dir="LTR">Can I solder </span><span dir="LTR">post of the resistor to botton of the spring?</span></p><p align="right" style="text-align: left;" dir="RTL" class="MsoNormal"><span dir="LTR">I had many problems with my DLE-55 spark plug cap and finally I noticed that botton spring of boot and resistor post have some disconnection sometimes.</span></p>
