RCU Forums - View Single Post - Leading Edge Question
Old 10-02-2010 | 11:50 PM
GW
Default Leading Edge Question
I am building a high wing trainer, the name I can't recall right now. Anyway, after assembly of the wing I realize I totally forgot to round the leading edge. Its flat on the bottom then 90 degrees up the front then about a 30 degree slant across the top. Question is what will happen if I leave it as is? I am sure I can just get a bit of curve around it if I have to.
Thanks in advance
GW
