ORIGINAL: GW
I am building a high wing trainer, <span style="color: #3366ff">the name I can't recall right now</span>. Anyway, after assembly of the wing<span style="color: #ff00ff"> I realize I totally forgot to round the leading edge.</span> Its flat on the bottom then 90 degrees up the front then about a 30 degree slant across the top. Question is <span style="color: #ff0000">what will happen if I leave it as is?</span> I am sure I can just get a bit of curve around it if I have to.
Thanks in advance
GW
Nothing will happen that you are in a position to judge any difference.
