RCU Forums - View Single Post - HELP PLEASE!!!!!!!
Old 10-04-2010 | 06:07 PM
BadAzzMaxx
Default RE: HELP PLEASE!!!!!!!
Unplug the ignition from the sensor, make sure you have a good battery hooked up to the ignition.
Now take a small wire and touch the two outside wires on the connecter that go to the sensor, You should get a spark each time you touch it and then take it off. If not your ignition is bad.
Milton
