RCU Forums - View Single Post - Carb on os 40 LA
Old 10-06-2010 | 09:46 PM
hugger-4641's Avatar
hugger-4641
Default RE: Carb on os 40 LA
Not sure what you mean by "turning the carb", but you can turn the engine sideways without any problems for the engine itself, it will run fine. I have several O.S. and other two strokes mounted like this. The problem you might have is getting the throttle push rod where you need it. You will have to route around or under the fuel tank to come thru the engine mount and fire wall and meet up with the linkage.
