RCU Forums - View Single Post - Carb on os 40 LA
Old 10-06-2010 | 10:00 PM
dash008
Default RE: Carb on os 40 LA
That's the point. If I can tun the carb around I will not have to move the throttle pushrod. This engine has a remote needle valve so the fuel line to the carb will just go around the other side of the engine.
This installation will be a little more down than sideways. Like around 100 degrees. I had heard of problems with inverted 2 strokes. While this will not be inverted, it won't be 90 degrees either. Just wondering if anyone has experience good or bad?
