flyerdarren
You will love the plane, it is such a fine machine. Everything is very smooth and very controlled, I found no bad tendancies to it.
I will say that if you are not comfortable landing a bit on the fast side you may have to work with it a bit. It will glide in ground effect forever if you let it, so I found that with a little hotter landing it was perfect. One word of caution though, upon landing DO NOT pull any up elevator until it is almost at a stop or it will jump back into the air on you
......been there - done that!
When looking down on plane make sure your landing gear is forward enough to see the atleast 1/2 the wheels infront of the wing or it has a really really bad tendancy to be very light in the tail and will nose over while taxiing on a grass runway.
By the way if you decide you don't like the plane for some reason feel free to pack it up and send it to me, I would be more than happy to give it a good home!
