Hi Bruno,
What is the flight duration of with the 8S 4500mAh? Since the model came light would you try higher capacity for increasing flight time when practicing? I am asking because I would be interested in at least 8,5 to 9 minutes of flying. eg. practicing P schedule and then some maneuvers. Not many pilots have used this setup, but according to Andrew Jesky (I read another thread) performs quite well.
Is the Hata prop the same as the latest Carbon by Delro? Is their mold based on the Hata prop? I guess that in windy conditions the 19 inch would perform a lot better than 21???
Final question I noticed that the battery is not fastened with velcro straps but with a carbon rod attached on a robart hinge. How does this system work really? Does it provide flexibility to use packs of other physical dimensions? You probably use the same on Addiction???
Sorry for making so many questions...but there is always a reason behind...
Thanks in advance,
Nikos
