RCU Forums - View Single Post - JS-2 16 scale
Old 10-09-2010 | 11:41 AM
BlackCat_2
Default RE: JS-2 16 scale
<span lang="en" class="long_text" id="result_box"><span title="" style="">In principle there is nothing daunting. </span><span title="" style="">In my work I used as a reference model 35 scale. </span><span title="" style="">Next - a lot of body parts can be done using auto fillers. </span><span title="">To her superb stick plastic parts. </span><span title="" style="">And it is perfectly formed and then processed sandpaper. </span><span title="" style="">The only problem - it's the dust from the fillers. </span><span title="" style="">All processing must be done under running water.
</span></span><span lang="en" class="long_text" id="result_box"><span title="" style="background-color: rgb(230, 236, 249); color: rgb(0, 0, 0);">As a basis I used the chassis of the KV-1 from Heng Long.
</span><span title="" style="">It is only necessary
</span><span title="" style="">1. </span><span title="">Reduce the width of the tub. </span><span title="" style="">This is done by cutting off the vertical walls on both sides and stitching on 6 - 7 mm plastic. </span><span title="" style="">Then the vertical wall with a roller stick back.
</span><span title="">2. </span><span title="" style="">It is necessary to move the upper rollers just below and to place them slightly above the other wheels. </span><span title="">Like the 35 scale model.
</span><span title="">3. </span><span title="" style="">You can then paste the desired angle rear bottom plate of the housing.
</span><span title="" style="">4. </span><span title="" style="">Slightly reduce the diameter of the rollers.</span></span><div style="" class="g-section" id="gt-res-tools"><div id="gt-res-listen" tabindex="0" class="gt-icon-c" style="display: none;"><span class="gt-icon-text">Прослушать</span></div><div id="gt-res-roman" style="display: none;" tabindex="0" class="gt-icon-c"><span class="gt-icon-text">На латинице</span></div></div><div style="display: none;" id="gt-res-dict"><h3>Словарь<span style="" id="gt-res-dict-more"> - Открыть словарную статью</span></h3></div><span lang="en" class="long_text" id="result_box"><span title="" style="">
</span></span>
ID:	1513400   Click image for larger version
