RE: Phase 3 EF - 16
Hi Cal.45ACP, Put masking tape around the servos and glue them in with epoxy. That way if you have to remove the servos for any reason, you can peel off the tape and the servos will not have any glue on them. Hot melt glue is not very strong and most silicon glues will melt the foam. Good luck with your F-16. It's a great flyer, even stock. Bob G.
