RCU Forums - View Single Post - Question on throws
Old 10-13-2010 | 07:00 AM
rcpattern
My Feedback: (45)
Default RE: Question on throws
Joe,
Do not just set the plane up by the book and then walk away. Most pattern plane throws are setup for guys flying Masters and FAI. You wont need as much throw when just starting out. Always better to start a little soft and as you advance through the pattern add more as needed. For Sportsman you probably wont use more than 12 degrees or so for ailerons and not much more on the elevator.
Arch
