RE: Crash Damage
So if everything seems to work such as motor speed from stick input, then the ESC might be ok. You also mentioned that the servos work and i assume you can bind with the receiver. Gyro light is also on? I don't know how else to test the ESC. A meter might help. You may discover that under load, the ESC will fail...
