RE: Pheonix Extra 330S 60-90 Size
hi cmoulder
when i assembled it originally, i had done research and raised the trailing edge of the wings 1/8th inch. i will double check the elevator trim, but i think they are about neutral. it is, generally, a nice flying plane, but you can't ever take your eye off it for half second! if i climb up high, cut throttle and let it dive straight down, at engine idle, when i pull out, you better be ready cause when you level off, it will dump the left wing into instant knife edge!
aa2dd
Bruce
