Need some help with Duel Aileron hook-up
Gator,
Futaba sells the equivalent item also. Yes, it works great for matching your servos. Unless you plan to use the inner and outer ailerons separately, in some bizarre way i can't envision, just use the Futaba syncrhonizer to join all 4 servos together to go to your aileron channel. You can also supply power to them separate from your receiver pack, if desired, to ease the load on your primary receiver pack.
