RCU Forums - View Single Post - Futaba or Hitec
Old 10-17-2010 | 07:12 PM
jetmech05
Default RE: Futaba or Hitec
You don't need all the servos in an aircraft to be the same...or even the same brand...you can even mix digital and analog.....HOWEVER....you can not mix servos on the same control surface....ie 2 3010's and 2 225's on the ailerons....control surfaces like 4 aileron servos all 4 need to be the same brand and model servo
