RCU Forums - View Single Post - Gaudius
Thread: Gaudius
Old 10-19-2010 | 11:18 AM
wagen017
Default RE: Gaudius
ORIGINAL: 4ptrol
If your CG is correct the airplane will trim completely neutral. I believe it presents well and can easily fly all classes. The 1st Gaudius was powered with a Plenty. The new one is powered by the Hacker Q-80. Both fly almost the same. I will say the front of the Gaudius is perfect for the Q-80. Very strong! You do not need to add the firewall if you use the Hacker. In either case you will be very satisfied with the power and by the way no cooling issues.
Larry
D2 VP
ORIGINAL: byoung466
Also 7lb 14oz w/o flight batteries. Equipment is Jetti 99, Pletty, JR8611 Rudder, 8411SA Aileron, 3421sa Elevator, LiFe hobbyzone 850mah flight battery.
ORIGINAL: HARRIS-G
This will be my first electric pattern model and i am thinking to power it with Hacker C50 14XL.
I wanted to know about the quality of the kit if someone find any issues on wing or stab alligment or what is the final weight with batteries and if requires too many mixes to fly KE.
Harris
I think Larry answered your questions. 7 lbs 14 oz = 3,58kg with above configuration.
I would go for a Q80 or a Pletty as power source.
Volkert
