RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 10-20-2010 | 03:55 PM
  #6132
captinjohn
Default RE: DL-50 engine
Get the right ring From Frank. The cyl is fine I bet. The reason why you exhaust bolts stripped is because you did not add a brace to the far end of the Jteck muffler. It is not good at all to support a exhaust with just 2 bolts.On a stock exhaust....the weight is so lite you can get away with only 2 exhaust bolts. Good Luck.....Capt,n
