RCU Forums - View Single Post - Best Prop for Vertical???
Old 08-01-2003 | 10:59 AM
Ian.W's Avatar
Ian.W
Default Best Prop for Vertical???
NO, high pitch gives you speed, large dia gives you thrust.
So, if youve got a large dia fine pitch prop, youll have loads of thrust, increased throttling and long verticals. Get a smaller dia, large pitch you'll have loads of speed, lousy throttling and crappy verticals
The nitro wont give you more torque, all nitro does is increases throttling and rpm.
i would stick with the prop your using
What fuel are you using?
ian
