RCU Forums - View Single Post - How I reinforced the Tamiya DF02 (Rising Storm) Chassis
Old 10-24-2010 | 06:55 PM
djnelsen
Default RE: How I reinforced the Tamiya DF02 (Rising Storm) Chassis
ORIGINAL: crunchNmunch
ORIGINAL: djnelsen
As I said before, the stock forks do very little to support the hingepin mounts since they're unsupported at their open ends... and if you look at how the chassis's broke, that's exactly what happened... the hingpin mounts tore out towards the open ends of the forks.
And yes, I agree that this mod may cause breaks to happen elsewhere, but I'd rather have something else break rather than the chassis.
Hmmm, that's odd. But that being the case I'd have tried making some kind of hingpin support to attach at the front of the gearcase.
As my concern now is that you've changed the stress point further back in the chassis and might cause the whole gearcase to sheer off with a lesser impact.
But who knows, and that's the fun of being a true hobbyist and trying to design a fix/better mousetrap.
Good luck.
Well, if the chassis breaks, it breaks... it was definitely going to break again in the same way, so if it breaks somewhere else, same result... a broken chassis is a broken chass: scrap plastic. Regardless of where it breaks.
Here's how I figure it: the more points you can make share the load, the less force each point sees. Having the hingepins supported by the chassis adds two extra points.
Having the forks pass into the spur case doesn't mean that the spur case is taking all the load. The hingepin supports are still taking some load, as are the closed ends of the fork.
I gotta shiny nickel that says something else breaks before the chassis does. And that's just fine with me. Replacing the chassis is a massive rebuild. Replacing shock towers or suspension arms isn't.
<br type="_moz" />
