RCU Forums - View Single Post - How I reinforced the Tamiya DF02 (Rising Storm) Chassis
Old 10-24-2010 | 07:33 PM
SyCo_VeNoM's Avatar
SyCo_VeNoM
Default RE: How I reinforced the Tamiya DF02 (Rising Storm) Chassis
ORIGINAL: crunchNmunch
ORIGINAL: djnelsen
ORIGINAL: SyCo_VeNoM
Ya the way they rip out there is really nothing you can add on to support it. Also I find epoxy (well JB weld at least) don't hold very well to this chassis. I've tried it on my current to cover the battery compartment gaps after I slightly damaged my lipo(which is proving to be a PITA to keep in) on my last chassis.
Another way you defintely could reinforce the chassis is if you got your hands on some MEK solvent... then you could make plastic ribs out of a number of differnet types of plastic: ABS, styrene, polycarbonate to name a few... you would then solvent bond the ribs to the chassis, which is made of ABS... solvent bonding is much more effective then gluing, as the end result is quite literally a single piece of plastic, not multiple pieces glued together.
With this technique you could go bananas reinforcing the chassis.
Interesting.
Where would one get MEK from?
saw it for $5 a quart on amazon
And about the design I think it was an oversight kind of like their stock shocks shafts being made of a soft metal, and prone to bending.
Honestly till I hit mine JUST right (skidding into a wall sideways at around 30mph) I didn't break it in that fashion for almost 9 months of bashing. Kinda like how toyota and the car companies are having recalls on brakes and stuff now a days for problems they didn't expect, and didn't happen till after the vehicle was on the streets.
