RCU Forums - View Single Post - How I reinforced the Tamiya DF02 (Rising Storm) Chassis
Old 10-24-2010 | 07:42 PM
djnelsen
Default RE: How I reinforced the Tamiya DF02 (Rising Storm) Chassis
ORIGINAL: crunchNmunch
I hear where you're trying to go with your modification, it's just that part of the reason they didn't make those hingepin supports more solid (without the ribbing) is that for whatever reason other things tended to break and they designed them as such as a sort of a "sheer point", kind of like a crumple zone in an automobile. They could have made them more solid, but apparently there's a reason they didn't. It could be something simple like that by them being so solid that every little bump and jump led to a broken suspension arm, or turnbuckle, or steering knuckle, and by building some give into that area is increased the overall deflection/flex of the front end and led to less breakage.
I don't know, mere speculation on my part, but that's generally been my experience with the designs of these cars from back in my day racing for AEand Losi and working on car design.
I don't buy it. Why design in a weak point such that the most critical and PITA part to replace is the part that breaks? Makes no sense.
It's just an inadequately engineered part of the car. Plain and simple.
I'm sure the engineers considered extending the fork into the chassis, but it would have meant a prohibitively complex tooling condition for the chassis (complex internal slides in the tool in order to form the necessary holes).
<br type="_moz" />
