RE: Aeroworks .60-.90 Proxy 260 CG problem
The directions will put the CG conservatively nose heavy. I'd start at 40% (from the leading edge) of the chord at the root (include the ailerons in measurement).
It will be correct when you can go inverted and maintain level with no elevator correction.
