RCU Forums - View Single Post - Balancing question.... problem?
Old 10-26-2010 | 08:38 PM
CGCINC's Avatar
CGCINC
Default RE: Balancing question.... problem?
ORIGINAL: Lnewqban
ORIGINAL: CGCINC
It is upside down but just won't sit still
Use a Vanessa rig, and don't look back:
http://home.mindspring.com/~the-plum...%20Machine.htm
http://www.rcuniverse.com/forum/m_70.../tm.htm#708060
As explained above, I believe that the problem you have is related to the natural instability of the situation where the CG is above the pivot point (skin of the wing in contact with the balancer).
As the schematic shows, the situation in which the CG hangs from a pivot (Vanessa), is self-stable.
Regards
Appreciate the links!!
That looks like a must have
