RE: Balancing question.... problem?
There is another option for balancing your Twist 3D 60 using your Great Planes balancer:
Hang equal weights at the exact same distance from the recommended CG, aft and forward.
By doing that, you will make the actual CG relocate itself below the wing, and then, your balancer will work properly.
