RCU Forums - View Single Post - Balancing question.... problem?
Old 10-26-2010 | 08:56 PM
CGCINC's Avatar
CGCINC
Default RE: Balancing question.... problem?
ORIGINAL: Lnewqban
There is another option for balancing your Twist 3D 60 using your Great Planes balancer:
Hand equal weights at the exact same distance from the recommended CG, aft and forward.
By doing that, you will make the actual CG relocate itself below the wing, and then, your balancer will work properly.
I like the Vanessa rig if I can figure it out... Thanks for the suggestions though!
