RCU Forums - View Single Post - AirPower Five Action Multi-function Valve...?
Old 10-27-2010 | 02:09 PM
POWER JET
Default AirPower Five Action Multi-function Valve...?
Hi guys..,
i'm trying to set up the EV5U valve in mode 3 position.
First of all the plane is a Hawk.I have the additional valve that's required when using the mode 3 setup.
I'm pointing out this because that's gonna help you to understand why i'm using mode 3 on setup of valve.On this mode the rear doors close after the gear is down for landing but nothing happens after the gear is down.The doors doesn't close again.Why?
I'm trying with the card to make some combinations ,as to reverse valves or gear or the door sequence but nothing....!
What am i doing wrong guys?
Thanks in advance for any replies....
