RE: castle v3 amp maximum
If you are talking about batteries, you can run as much as you like, minimum I would run is 150. The motor draws the amps from the batteries and will only take what it needs. If yu have a 200 amp battery, and your motor needs 150, it will only use 150. You will not fry your esc by having too many amps.</p>
