RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 10-28-2010 | 07:19 PM
  #1443
cappaj1's Avatar
cappaj1
Default RE: Venus II
I am putting the belly pan on tonight and I epoxied some plywood rings to 2" paper tubes and need to insert those into the belly pan and epoxy with microballoons the pan to the bottom of the wing with these tubes lined up. Is there any trick to lining the tubes up so the wing bolts will find their mark when installing and removing the wing, or any other tips on this part of the assembly? Thanks in advance for any suggestions!
