RE: Venus II
Glue in the tubes with the wing bolted to the fuse. With the nylon wing bolts in position the tubes will center around them. If you use epoxy (30-minute) with microballoons the epoxy won't flow/run too much and you SHOULDN'T get enough epoxy on the heads of the bolts to glue them down. Epoxyespecially a small amount of itwon't stick to the wing bolts.
