RCU Forums - View Single Post - Tamiya Leopard 2A6
Old 10-30-2010 | 11:45 AM
vollenc
Default RE: Tamiya Leopard 2A6
Hi Googly,
Thank you, much appreciated. Looking forward to seeing your model. The antenna shaft is .020" styrene rod, the base is .032" styrene rod drilled to #74 and the ball is the head of a Size 17 Ball Pin. I was originally going to use music wire for the shaft but I would have had to order it. The styrene isn't as delicate as I was at first concerned.
