ORIGINAL: res3567
I have the nitro version....if the boat starts to hop around...adjust the trim tabs immediately. The stock plastic prop wont hold up under contant jumping. Mine broke in two places. Also, consider the metal props as well.
adjusting the CG helps alot with this
in my brushless SV I've moved the batteries almost 2" further forward and kept my trims tabs at 0*
and the strut at neutral
