ORIGINAL: jride1999
ok thanx.i wanna upgrade my bat,everything is stock sept grim racer prop.im new to elect boats,always owned nitro car an this is my first boat. if i upgrade my bat,do i need to change anything else?
In my opinion not much needs upgraded on an SV boat
A good prop is always good.. I like using a CF45 and CF48 prop
I've also heard a S230 and S235 work amazing on this boat
And good lipos with a C rating of 30c and higher will give the boat more punch and speed with the bigger props
And always check your temps when you use a bigger prop to make sure things are running in the safe zone
And punch it!
