part | brand | model | quantity |
Order 1 | | | |
MOTOR | RCMK | New 520S EVO motor | 1 |
MOTOR | RCMK | Throttle Arm | 2 |
Engine mount | RCMK | RCMK Engine Mount for RZ254 | 1 |
COOLING | RCMK | 0402000001 - Water Outlet | 6 |
SHAFT assembly | RMCK | 2406000012 - Flexible wire 250 80cm | 1 |
SHAFT assembly | RMCK | 2406000014 - Flexible wire 250 R 80cm | 1 |
SHAFT assembly | RMCK | 0809000002 - Brass Teflon Tube 1/4 60mm | 2 |
SHAFT assembly | RMCK | 0809000003-Brass tube mount | 2 |
Servo Linkage | RMCK | 0811000001 - Linkage Rod 31 | 4 |
Engine mount | RMCK | Zenoah Engine mount rail(Part No.0201000007) | 1 |
Order 2 | brand | | qty |
DRIVES | RMCK | RCMK Arneson Drive set (twin drives with linkage) | 1 |
DRIVES | RMCK | Spare metal drive line+joint | 2 |
EXHAUST | RCMK | 88mm 90header | 1 |
EXHAUST | RMCK | 58mm 90 header | 1 |
SCALE | RMCK | Cowl Lock Front | 1 |
WATER LINE | RMCK | Fitting AW M5-90 | 4 |
EXHAUST | RMCK | Muffler Mount M2 | 1 |
EXHAUST | RMCK | Muffler End 3 | 2 |
EXHAUST | RMCK | Muffler End 2 | 2 |
| AGREED/paid for | | |
| | Brass Tube 250 | 1 |
| | Engine Spares + Gaskets (carburator and head are important!) | 2 |
part | brand | model | qty. |
| | | 0 |
ELECTRICS | PMB | Water Pump | 0 |
ELECTRICS | PMB | GA20 - Waterproof Switch | 1 |
TRIM TABS | WD200 | order 6002 - Trim Tab 2 | 1 |
GEARBOX | WD200 | order 2010 - GETRIEBE 1 | 1 |
FUEL TANK | WD200 | order 3115 - Fuel tank Big (aluminium grey) | 1 |
SEVO BOX | WD200 | order4020 - 160*200mm (aluminium grey) | 1 |
| | feet for RC box + feet for internal division panel? | |
SHAFT assembly | MHZ | 2256-Flexwellensicherung mit Abfanglager 6,35 mm | 2 |
COOLING | MHZ | 1585/P Water Pump | 2 |
FUEL | MHZ | 1906 N -Schnellbetankungs - Ventil für Benzin | 2 |
BODY | MHZ | 1798/K-Cowl-Loks klein, 1 Stck. | 3 |
BODY | MHZ | 1016/N - Auto Bailer New | 1 |
SERVO | MHZ | 1644 - Rubber cuff - 8/35 mm | 2 |
| MHZ | 1649 - Rubber cuff - 10/56mm | 2 |
| MHZ | 1586Y - Y Splitter f. 3,5-5mm Tube | 2 |
| MHZ | 1859 - Gas - Kabelsatz für Walbro Vergaser - NEU | 1 |
| MHZ | 1551 - Silicon Schlauch / Hose 3 mm | 1 |
BATTERY | CHEAP BATTERY PACKS | 6v - 5000Mah Custo NIMH Pack | 1 |
COOLING | SHALLER COMPOSITI | Various Building Materials | 1 |
SERVO | HOBBY KING/BMS | BMS-L530DMG+HS 1/5 Scale Digital Servo (MG) 19.8kg / .15sec / 140.5g | 3 |
KILL SWITCH | KILLER RC | Killer RC - Killer Bee Kit 2 | 2 |
Painting | KORO DESIGN | Custom Paint Job | 1 |
Building Materials | PROMISE HOBBY | M4 threaded water nipples for rc boat 5pcs | 1 |
Building Materials | PROMISE HOBBY | M5 threaded water nipples for rc boat-5pcs | 1 |
EXHAUST | PROMISE HOBBY | Dual water cool flange for 23-26cc gas engine-silver | 2 |
EXHAUST | PROMISE HOBBY | fluororubber o-ring for exhause pipe & manifold-6 pcs | 1 |
EXHAUST | PROMISE HOBBY | alu exhaust pipe saver for 7/8" or 22mm header | 2 |
EXHAUST | PROMISE HOBBY | Stainless steel mufflered pipe for marine engine boat | 2 |
