RE: Motor won't run?
ALWAYS turn on the tx before you power up plane otherwise your motor wont run you will then hear the ESC count the battery cells and servos like beep beep beep silence then another 3 beeps then away it goes the motor I mean off course before you put prop on check direction of rotation
