RE: Pheonix Extra 330S 60-90 Size
It isn't a mix per se. You turn on the flaperon function then set the control limits for each position of the flap switch. If you are using 2 channels for your ailerons you already have flaperons turned on, you now need to set values for each position of the flap switch.
