RE: setting up thrust down and right hand
Thanks Rodney,
Mine is balanced at 25% from LE,I can easily take off some weight from the front as I moved the engine forward with spacers to do that.
Not sure if I can get inanother flight before oldman winter sets in as the winds are unpredictable but will try, thanks
What kit is yours? What engine do you have?
I am using a OS FT-120 Gemini engine (4 stroke) which leaves slightly underpowered but lifts off well in no wind days.
Rafeek
