RE: SEAWIND EP
After you make sure that the ailerons are not binding, try moving the CG back. Although the manual lists the preferred CG as 25 mm back from the leading edge, I typically fly with it back 31 +/- mm and the seawind is still pretty docile. Landings become easier too. Others go as far back as the support spar.
Regards,
Bob
