RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 11-08-2010 | 04:58 PM
  #1495
maynardrupp
Default RE: Venus II
ORIGINAL: cappaj1
ORIGINAL: maynardrupp
Use elevator and aux 2. On My Spectrum DX7 I use either mix #6 or #7. These are the only 2 that adjust trim with the master channel. I think the 9303 procedure is different, but elev. and aux2 are the channels. I use aileron and aux1 for the flaperons.
Thanks, I'll use the channels you said. I don't use flaperons though - do they help with landings? Do they take away any of the control left to right when landing?
On my DX-7 you need to turn flaperons on and set the flap travel to zero I believe, in order to use the 2 channels for the ailerons. You can also use these for flaps or spoilerons, (flaps both up), if you want. I don't think we need that on the Venus.
