RCU Forums - View Single Post - DA & DLE ignition module ?
Old 11-09-2010 | 08:36 PM
jedijody's Avatar
jedijody
Default RE: DA & DLE ignition module ?
An Rcexl ignition will work on any engine set up for electronic ignition, the sensor location is the only thing that needs to be worked out for proper ignition timing. For many engines that use a different proprietary ignition system it may require drilling and tapping a new hole or two as Milton mentioned, just depends on how the original ignition was timed.
To address the specific engine in the OP, it would require drilling and tapping at least one new hole. Timing should be properly re-set on any engine when replacing modules or sensors even within the same brand/manufacturer.
