DA & DLE ignition module ?
Old 11-09-2010 | 06:32 PM
David DeWitt's Avatar
My Feedback: (289)
Default DA & DLE ignition module ?
Will a 100 DLE ignition module work properly on a DA 100. Any difference in the timming.
Old 11-09-2010 | 06:34 PM
Default RE: DA & DLE ignition module ?
No they will not, two completly different units.
Milton
Old 11-09-2010 | 07:19 PM
JoeAirPort's Avatar
My Feedback: (41)
Timing is different and you need to replace the DA sensor with an RCEXL. Timing is like CH ignitions, 28-30 BTDC. Milton has a nice video for mounting the sensor.
Old 11-09-2010 | 07:27 PM
My Feedback: (13)
as long as you use the dle timing sensor in place of the DA, it still would not work?
and you would have to set timing 28-30 degrees BTDC.
i switch one of my DA50's to a Rcxel ignition with no problems.
Old 11-09-2010 | 07:44 PM
I have changed about 30 DA and ZDZ in the last year, If you can drill a hole and tap some threads, presto it is done.
Milton
Old 11-09-2010 | 08:12 PM
MetallicaJunkie's Avatar
they work great....my DL(E)s run like champs with rcxcels....my brother converted his 3w157(new style) to RCXcel, he got lucky his was plug and play, all he did was swap out the ignition , and mount the correct hall sesnor,and now it runs better than ever.
Old 11-09-2010 | 08:36 PM
jedijody's Avatar
An Rcexl ignition will work on any engine set up for electronic ignition, the sensor location is the only thing that needs to be worked out for proper ignition timing. For many engines that use a different proprietary ignition system it may require drilling and tapping a new hole or two as Milton mentioned, just depends on how the original ignition was timed.
To address the specific engine in the OP, it would require drilling and tapping at least one new hole. Timing should be properly re-set on any engine when replacing modules or sensors even within the same brand/manufacturer.
Old 11-10-2010 | 09:35 AM
rcexl's Avatar
Look the following illustration
</p>
Old 11-10-2010 | 10:39 AM
Very nice illustration.
Can I use the pictures on my site.
Here is some information on 3W engines
You will have to copy and paste, then put in the www.
rcextremepower.net/index.php?board=6.0
Milton
Old 11-10-2010 | 10:44 AM
Walt and Sage's Avatar
NICE Rcexl.... Thank You for the photos....
Old 11-10-2010 | 11:31 AM
JoeAirPort's Avatar
My Feedback: (41)
I can't remember, does the spark happen on leading edge of the magnet or the trailing edge of the magnet? Must be trailing since that's where he has the line?
Old 11-10-2010 | 11:33 AM
Trailing edge.
Milton
Old 11-10-2010 | 12:29 PM
JoeAirPort's Avatar
My Feedback: (41)
Thanks Milt.
Old 11-10-2010 | 02:32 PM
NO REPLY...Just another way. A simple ring with magnet can be slip fit over hub. No need to tap holes in engine...and with the set-screw you can set timing in a jiffy. Can be placed on about every engine....within reason!Tapping the holes can bea mistake you will spend $$ to fix. Capt,n
Old 11-10-2010 | 05:44 PM
ggraham500's Avatar
I'm impressed with your ring idea. Where did you get the ring with magnet for a Rcexl ignition, etc?
Old 11-10-2010 | 05:53 PM
ORIGINAL: rcexl
</p>
Also the RCEXL twin CM6 ignition can be mounted on the DA100 engine. Same procedure as pictures for the DA50R.
Be careful wit screws supplied with the engine, not metric size. The screws to fix the sensor housing supplied with RCEXL ignition is M3 size.
Also , you must turn the diode inside the sensor housing, or test for proper work before put the retainer clip. . The magnet on the DA and DLE are reverse polarized.
Here in my country, many DA owners , ask me for a RCEXL replacement. Same performance for a fraction of money. The DA50 ignition here is 110 EUR (about 150USD).....
And you can put a RCEXL mini-tachometer on the specific wire of RCEXL ignition ..... (why DA does not give this feature ?)
Regards
Old 11-10-2010 | 06:23 PM
ORIGINAL: ggraham500
I made the ring form a lot o round stock I have.... using my lathe. I bet some guys near you may have a lathe. Anything round is very simple to make...like timing rings. You may have a friend at a shop that clould make you one from round scrap stock. Drill the inside with bigger and bigger drills then the last inside dia is done with a small boring bar. Capt,n
Old 11-16-2010 | 06:32 PM
My Feedback: (289)
Thanks for all the replies. I did the RC Exl conversion and used the clamp on sensor so no drilling was involved. Engine runs great!
Old 11-16-2010 | 10:49 PM
JoeAirPort's Avatar
My Feedback: (41)
Cool. They are nice ignitions.
