ORIGINAL: ferio
Hi Winglift,
Did you use the foam tape that was included in the kit to mount the aileron servos? I have an EZ beat On kit too, but hesitant to use that method. I'm planning to use a YS53 or a YS63,but due to engine vibrations, that mounting method would not be a good idea. Might need to secure them using light ply and servo screws. Just my opinion.
Gerard
Gerard, At first I was hesitant to use this method, but decided to go ahead with it. When I installed the servos I carefully positioned them and then pressed them onto the mount and I am very confident about it. They are rock solid in the mount. The foam tape supplied is very effective. Just be sure that you have the servo in the right position before pressing it onto the mount because it is not going to move. Again, I was like you, but now believe it works just fine.
