RCU Forums - View Single Post - DA & DLE ignition module ?
Old 11-10-2010 | 02:32 PM
captinjohn
Default RE: DA & DLE ignition module ?
NO REPLY...Just another way. A simple ring with magnet can be slip fit over hub. No need to tap holes in engine...and with the set-screw you can set timing in a jiffy. Can be placed on about every engine....within reason!Tapping the holes can bea mistake you will spend $$ to fix. Capt,n
