RCU Forums - View Single Post - DA & DLE ignition module ?
Old 11-10-2010 | 06:23 PM
captinjohn
Default RE: DA & DLE ignition module ?
ORIGINAL: ggraham500
I'm impressed with your ring idea. Where did you get the ring with magnet for a Rcexl ignition, etc?
I made the ring form a lot o round stock I have.... using my lathe. I bet some guys near you may have a lathe. Anything round is very simple to make...like timing rings. You may have a friend at a shop that clould make you one from round scrap stock. Drill the inside with bigger and bigger drills then the last inside dia is done with a small boring bar. Capt,n
