RE: DON MUDDIMAN FLYING MACHINE SHORT KIT BUILD
More work done on the fuse and will be starting the wing tomorrow. I have an idea for running the servo extensions to the two wing aileron servos. If it works, I will post pictures later this weekend. On a bigger airfoil, one can clamp the ribs together and then drill a hole through all of them for a tube to be inserterd through which the servo extensions are run. The ribs for the FM wing, in my opinion, are to small to risk drilling a hole through. I'll see if my idea works in the next couple of days.
