RCU Forums - View Single Post - Ignition Issues?
Old 11-13-2010 | 01:16 PM
WacoNut's Avatar
WacoNut
Default RE: Ignition Issues?
Got to remember back to basics,
I forgot to check and set the plug gap, it was less than .010 I opened it up to the recommended .020 and shot some starting fluid into the cylinder and it is running fine now. Was running a bit lean and quitting on the high end, 1/2 open on the high speed needle and the engine is running fine. Pulls pretty good with a 23x10 prop.
Later!!
Anthony
