RCU Forums - View Single Post - DON MUDDIMAN FLYING MACHINE SHORT KIT BUILD
Old 11-13-2010 | 06:40 PM
airbusdrvr
Default RE: DON MUDDIMAN FLYING MACHINE SHORT KIT BUILD
A bit of progress the last several days. First, some pictures of how I made a tunnel for the servo extensions needed for two wing mounted aileron servos. The basic wing and fuse are finished. I'm using a Hangar 9 Ultra Stick 40 landing gear and so far am planning to use an OS 55 AX for power. In addition to the servo extension tunnel built into the wing, I added a second 1/4"X1/4" strip inside the wing along side the 1/4"X1/4" TE strip. This will add extra strength to the area where the aileron hinges are attached.
